Boom wanted
I just made one last week out of 48 x 1.6mm anodized tube. I used it for the first time on Sunday at while it bowed a touch it seemed to be strong enough. I modified my old gooseneck to fit.
This place: https:/
You can buy 50mm Aluminium round section from AHPC/Goodalls which the 50mm female/male gooseneck which he sells is made to fit.
I didnt bother with an outhaul track on the new boom, and went for an outhaul system similar to this: ( https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcQvjNtCWrSRnOd3ORId-YIXwzkD4GYNr9tFxYfqiYlLLXBv8W6JoDTzOJY) with a purchase system similar to the paper tiger. The line I pull for the outhaul comes through one side of a ronstan RF5 on the boom, and then the RF5 has been modified with an additional cleat and pulley to allow the mast rotation to got through the other side. I think there is a picture of a similar setup on the Mozzie Pics section.
Purchase System can be seen here: http:/
Hi Greg
I use a Pacer / Old Paper tiger/ Sabre section.
You can get a cut length or full lenght from Keeley Marine Supplies
Section Code: K02
These Sections are not Anodised
Alternative cut the track off a cut down mossie mast or current PT mast.
You can get tubes e.g. 50mm. i personally don't like as i like to make an outhaul that slides easy inside the boom. On a round section you basically rig up outhaul same as a laser with a dyneema strop. Sometimes they don't like sliding along the boom.
Im making 3 booms in the next 2 weeks. I also make the outhaul cars. Ill post pics later. I have a 3mm 50x40mm in a egg shape, with 1 x 8mm rod welded through the bottom with a 25mm nylon wheel on each side of the plate wide enough to hit the edge of the section. (no captive pins to hold wheels on).
I have a block on the outboard end of the plate ( Greg can post pic) as its a 2:1 system.
Matt
If you end up with a non-anodised section a coat of Penetrol (about $30 from bunnings) will keep it shinny and nice (no white powder or finger prints). Redo it at the end of each season. Even better is shark hide or Nyalic but both will hurt the bank balance more.
At the gooseneck end i use a k02 to suit boom section from keeley marine supplies.the riley gooseneck slides straight in. On The gooseneck i grind out the pressed in pin and replace with bolt and the shaft that goes in the plug , i weld a nut behind it so the boom cant fall off during a race
Matt
Hi Greg, I'm just going through the gotta build a new boom thing too. LR sails up here in Brisbane have some new but scratched Mosquito mast sections for $300.
More than happy to let you have a third of it for $100. I will even rip the sail track off with the plasma if you want.
Alan
- 3,699 Online
