First Mosquito
Hi there,
I have just bought my first mosquito sail # 1720. I have done a fair amount of sailing in the past and am confident with trapeze etc. just wondering what any tips and tricks are and also what events would be good to race against other mozzies? Also, what is a trick to raising the mast with one or 2 people?
Hi Haz,
Where will you be sailing from?
There are as many ways of getting the mast up as there are boats. I lay the mast forward with the step under the main beam and attach all 3 stays loosely. I then simply walk the mast upright then pick it up and put it on the step and tighten the stays. Coming down is the reverse. I usually either get the crew to steady the foot so it doesn't kick sideways, or loosely tie it off.
Cheers
Trevor
Hi Haz,
Welcome.
I do the mast thing the similar to Trevor, side stays on, forestay loose, use the dolphin striker for leverage if needed tighten the forestay when its up. just do the reverse when taking down. I find it best as a one man operation (2 can get in the way ) the trick is to get the mast vertical (and keeping it vertical)prior to lifting to the mast step.
Ross
No Turbulence
1774
- 7,032 Online
