New to Mozzies
G'day all,
I'm new to the mozzie fraternity, having just purchased 'First Try' #1769, on the first (last Saturday)
Raced kiteless on Sunday, but was still a blast! Having stepped up from a 'Sundance 14' the difference is staggering.
This forum has proved to be a fantastic resource, along with the website. It's great to see that there are so many committed and knowledgable folk out there, happy to share their expertise.
I look forward to further technical discussions, once my brain processes what I've already read!
Cheers!
Hi Hack, it sounds ridiculous but you should try make it to nationals even if only for a few days. You will jump up the learning curve soo quick and know all the right techniques to go away and practice.
Glad you're enjoying your new boat <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
P.M me if you need a spot to pitch a tent.
Thanks for the encouragement guys! Nats are out of the question this time, but maybe next year!
Hornbag! Be careful what you wish for! Spent the week keeping Ronstan viable, so I'm good to go!
For the rest of the country, Port Vincent is right up there with the best places to sail in the known world! You owe it to yourselves to get over here! Some SA sailors know what I'm talking about. Keen to keep you updated on our Mozzie progress over here....if Steve and I don't sink each other in the meantime....
hi im new to the mozzies to I just bought exgalibur 1544 looking forward to sailing it they have winter racing here once a month at Yarrawonga hope to try it out this sunday then might be after some advice as I haven't sailed for about 10 years but carnt wait im Michael
Welcome to the swarm Michael <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
and a welcome to your new mozzie 1544
exgalibur
<img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
the boat doesn't showup on the Mosquito Catamaran History by Sail number pages ( http:/
<img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
as for your question... wondering where to get new center boards how mutch to also where to get new boom section
best to start a new thread for the bits your chasing rather than adding to an older thread, new threads get far more attention <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
More than likely there be a member that has some 2nd hand units laying around and then there's always the brand spanking new jobs.... all depends on the depth of the wallet
Hi Michael,
and again welcome to the swarm.
Booms you can use anything that fits through a 80mm circle. I am currently using a length of Mossie Mast with the track cut off. Have used Paper Tiger/Sabre/Arrow mast section cut to length and just round tube less than 80mm from local alloy supplier cut to length, know of a Laser mast being used and some use carbon tube again less than 80mm, it's up to you what you can find.
New centreboards JK Fibreglass (bendigo) make them for Mossies. Second hand, many A class boards fit,
simple enough to confuse the numbers, I had to look twice ..... <img src="<>/crazy.gif" alt="crazy" title="crazy" height="15" width="15" />
1455 was on eBay not so long ago, was for sale in Ballarat Victoria from memory.....
just noticed this......
1434 J.I.B.E.
1727 Atreus
<img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
2 more and you'll have your own fleet
<img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
& did you get that pic I emailed you ???
Hi swatter,
The easiest way to put up an old (heavy) Mossie mast is with two people! However if you must do it by yourself, there are a number of ways you can do it. No doubt others here will have some advice for you, but this is what I do...
From what you said on the other thread, you have a hinge plate on the mast (newer masts don't have that). As you said, you need to raise the top end of the mast so that you can get the hinge pin in the holes.
I got a piece of steel tube (about 1.8 m long) and welded some feet on it so that it will stand vertically. A portable post if you like. I stand the post at the back of the boat, about a metre behind.
About half way up I have a piece of steel attached to the post so that I can sit the mast on it. I sit the the mast there and get the hinge pin in the holes. Then I lift the mast up and sit it on top of the post. I have another piece of steel attached to the top of the post to sit the mast on.
Then I get on the trampoline, take hold of the mast and stand it up. It is quite easy to lift the mast from the top of the post into the vertical position.
It can be a bit tricky holding mast up, and attaching the forestay to the bridle, so you need to be careful with that.
This question is asked so often I've just added a page to the website on the topic.
Now it just needs a few pictures.
Thanks for that Tim.
The hinge plates on our old boats (1140 and 1434) are fixed to the beam with the hinge at the back, which is why we have been putting up the mast from the back. I suppose it would be possible to take them off and turn them around so the hinge is at the front.
Simple enough .......
Thanks for that example
That would be good if you can do that Greg, a few pics with a ruler or tape measure in the shot will make life far easier too....even a short vid of it actually opening / closing would help <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Email them through to me when you can and we'll go from there
1182 never had one and there's no sign of one ever being fitted to her either so I'd want to make 2 for my two mozzies for starters and if there's an interest or demand we can make as many as required from there.
- 5,811 Online
