New to Mozzies
Hi all,
there is one thing some may be missing here. That is that retrofitting is not possible (to my knowledge) on mast bases unless the mast rotation pivot is bolted in.
The mast bases that came standard with these had a pivot that had a space before the cone of the pin that fits in the cup that captured the plate, keeping it attached to the mast base.
For instance on the mast base on 1766 the pivot is pressed into the cast alloy base and the cone that goes into the cup is flush underneath the alloy, no room to capture the plate.
But all is possible if you bolt through a new pivot or make a complete new base.
That's the tough one to get around, but like every thing if there's a will ........
Had a look at a spare base I have here and without destroying it I think it wouldn't take much to remove the cast in stainless part....... The alternative is to simply use the cast in stainless bit and bore through it and cut a thread for a new bolt.
Personally I'd like the cone on the beam and the cup on the mast, it would be simple to re-machine the cone into a cup and retro fit a new cone to the beam where the cup usually sits !!!!!!
Big advantage for me is no sand in the beam-cup and therefore no horrid grinding every tack <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Problem solved
<img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
I think it can be done without replacing the mast rotation pivot. It is a bit hard to explain without pictures but I am thinking of a piece of curved of 1.6mm stainless that can be riveted to the bottom front of the mast. Welded to that would be a hinge part which matches the other half of the hinge attached to the beam.
Hi swatter,
Glad to hear that you are making some progress with the mast raising. Using your trailer and mast stand is a good idea.
I have found it quite easy putting the mast up by myself from the back the way I described earlier.
I know that some people (Tim, Gary etc) say that it is easy to put the mast up from the front without a hinge, but that hasn't been our experience.
We have had difficulties putting up the mast from the front on our new boat 1727 which doesn't have a hinge. I am at the moment making a hinge for 1727 which will be on the front of the mast. I will post some pics when it is finished.
Greg.
I've finally done it... Below is a series of pics which hopefully are self explanatory
![[Linked Image]](http://s1.postimg.org/yovixhawv/MH1.jpg)
![[Linked Image]](http://s30.postimg.org/wzxsokya9/MH2.jpg)
![[Linked Image]](http://s3.postimg.org/4n41ay66r/MH3.jpg)
![[Linked Image]](http://s8.postimg.org/p2414aqyt/MH4.jpg)
![[Linked Image]](http://s21.postimg.org/q9zng8trr/MH5.jpg)
<img src="http:/
<img src="http:/
<img src="http:/
- 5,602 Online
