Victorian State Titles 2007
Just in case people haven't thought about the state titles yet here is a link to Somers Y.C. <a href=
ttp://www.somersyc.org.au/
target=
_blank
>ttp://www.somersyc.org.au/ for the location of the upcoming state titles which are only 6 weeks away. <img src=
A link to the notice of race is here http:/
We hope to have a full contingent of 12 Mozzies from Somers <img src=
/> and would like to hear from others intending to participate.
Peter
Col,
Boats can be stored in the boat yard for the duration of the event. <img src=
/> Trailer storage might be a different proposition <img src=
/> but there is storage outside the boat yard in the main carpark amongst the trees. It may pay to either lock the trailer coffin/s or take any valuables with you.
Peter
Hey there
Myself(Ben) and Will are going to make the trip from sydney for some sailing lessions from all the seasoned mozzie racers.
I have purchaced a old mozzie it will be painted this weekend and ready to make the trip down.
Looking foward to seeing the other boats.
Hopefully there will be a big turn out!!!
Ben and Will,
Great to hear that you are coming all the way from Sydney for the state titles. <img src=
/> <img src=
Look forward to seeing you guys at Somers. <img src=
It should be a great event. More like a nationals than a state titles with 3 states represented. <img src=
Peter
I thought you already had a boat! Careful or you can end up with a back yard full of boats (I speak from experience).
Are you going to double-deck the two Mozzies down to Somers?
Hi Tim
We are doubling the boats down there.
We are both hoping to sell all boats before next season so we can get ourselves a newer fiberglass boat.
Just dont think building a new mossie out of marine ply will keep up with the glass boats so Ive decided to can building one.
regards
William
Ben and Will,
The boat yard will be open on the Friday afternoon so you can set up. <img src=
If we end up running out of space for trailers a couple of the Somers Mozzie sailors (me included) have offered to store trailers at their houses.
Peter
Hi all,
don't mean to put a damper on things but you will have to survive with out me. <img src=
/>. Nobody wanted to lend me the worlds fastest Mossie, so I am not coming <img src=
Will be going for a blast from the past instead, I use to sail Fireballs and they are having states at Paynesville, so unlike some classes <img src=
/>, they are lending me a boat. I will crew and Ben will skipper, so maybe he will get his own back after crewing for me on the Mossie <img src=
/>. This could be ugly <img src=
Good luck all, hope you enjoy it as much as I will <img src=
Regards Gary. <img src=
Thats a shame Gary. I was having an idle thought the other day about hull shapes and I remembered I used to swap rigs on boats, eg 16foot skiff rig on a cherub, that sort of stuff. Altered would be an ideal test platform to fit a Mozzy rig to and with you racing it against other Mozzies we could get some good data, ever been tempted to try it?
Darryn
1704
Hi Darryn,
Altered
has been called a Mutant Mossie but that would be ridiculous. It would probably be slower than a Mossie as hulls are heavier, would be awesome though in 20 kts. plus upwind as all that width would make it very easy to handle. <img src=
Have allways wondered more the other way, putting my rig on Mossie Hulls <img src=
/>, that would be interesting, would probably have to make platform wider though. <img src=
Ben, its the wheels that I am having the trouble with. I cant find any that have a large enough axle to hold the weight so far away from the hub centre.
I was trying to put the wheels under the tramp rather than on the outside to minimise the total length (width) of the rollers for transport.
Hi Trevor
The wheels Ive got to build rollers are about (guessing) 250mm in diameter and about 150mm wide, you can get them from disposal stores and engineering supply stores, they have a hard plastic rim, and metal bearing arrangement, if you knock out/punch out the bearing, this leaves about a 50mm hole with the slight taper in the middle, file the taper down flat, so a piece of 50mm aluminium tube can be pushed through, a couple of sleeves each side to hold the wheel in the one place and attach the cradles, most of these type (that I have seen) have wheels on the inside, but I've seen one with them on the outside.
PS the cheapest Ive seen the same wheels as I have is $40 at a market.
Regards
Hey there Trevor
we are using the extra wide wheel borrow plastic wheel.
The axle will be 48mm alloy we are using pvc bushes.
Prob make a fiber glass hull support with the wheels inside the hulls.
getting the wheels for about $80
I will post a photo as soon as its finished prob wed.
Just a quick reminder to all those attending the state titles, if you haven't put your entry in yet you can do so on Saturday morning at the yacht club. <img src=
/> Registration is between 8:00 and 10:00 am. <img src=
If you intend to do so don't forget your AYF membership number and your insurance policy number. I'd hate for anyone to forget these important details or anything else like rudders, mainsheets, trapeze harnesses, life jackets, hats, tents etc. <img src=
/> <img src=
/> <img src=
Peter <img src=
- 1,737 Online
