Righting Difficulties/Net Replacement
2 Users
(@Anonymous 39510)
[#19254]
How difficult do you guys find righting a M5.5 (’18)? I’m about 155 pounds and just under six feet, and I’m wondering if I could right it by myself just using a line or if I need a righting pole?
On another note:
Anyone knows where I could get a replacement tramp for a ’95 M5.5? Or any companies that produce aftermarket tramps that could be installed?
Thanks.
Posted : January 22, 2007 4:06 pm
(@catman)
You are going to need help righting that boat. I've used a large Murrays righting bag to right by myself and it worked better than two people. I never tried a pole system so I can't comment other to say from what I've seen-read, some people like them and some have trouble with them.
Hobie Gary has a system he devloped that seems to work well,haven't tried it or seen it. I sure he'll comment when he sees this.
If you decide to go with the bag make sure you tie a stopper knot at the end of the line that raises the bag up. It could come uncleated after the boat is righted and before you get a chance to recover it. Result one lost sinking bag.
How do I know this?? never mind. <img src=
Posted : January 23, 2007 10:09 am
(@catman)
Forgot about the tramp. Try here.
http://www.multihullnets.com/
Not cheap but very well made. You might be able to save a few dollars by having a friendly boat dealer or such order it for you ( they get it wholesale ) and pass a little saving on to you.
You can also check out the catsailor store.
Just so you know, the Mystere 5.5 and the 6.0 tramp are the same.
Posted : January 23, 2007 10:22 am
(@Anonymous 38621)
You could always take the tramp to a few local sail/canvas shops. They may be able to recreate a cheap one. Bay Sails in Hamilton is a Haarstick dealer but does a lot of canvas work and he has repaired my tramp before.
Posted : January 23, 2007 10:43 am
(@Anonymous 39510)
Thanks...going to have to check those choices out. The bag might be a good option. Not as expensive and probobly less complicated.
Posted : January 23, 2007 2:50 pm
