about repairing of Prindle 19
rafael
(@rafa)
[#15439]
Hi
I have a prindle 19 and the chainplates that hold the stay to the hull (both hulls), which go underneath the fiberglass, are corroding pretty bad (the cat is old), and I want to change them, how do I gt to them, should I tear off the upper deck of the hull? or what??
Thanks for u help
Rafa
Posted : May 12, 2005 2:24 am
 robi
(@robi)
You will get better responce if you posted this in the general discussion area.
Posted : May 12, 2005 10:07 am
(@Anonymous 1624)
I don't own a prindle but I would guess that if the chainplates are not bolted or riveted on on the outside of the hull they are likely accessible from the inside of the hull. I don't think they would be totally glassed in, but who knows? It's possible thay you may have to cut a port hole into the deck to get close to these. Robi is right you will get more response from Prindle sailors in the
General Discussion forum. People are always glad to help.
Posted : May 28, 2005 7:30 pm
(@Anonymous 10039)
I have a P19 and am familiar with the chainplate mounts. The chainplates are each secured to the sides of the hulls by three pan head machine screws which pierce the hull skins. These screws go through the chainplates and thread into a gudgeon plate which is bonded to the inner hull surface. Removing the three machine screws should release the chainplates which will slide upward through the small exit slots. You can prevent corrosion of the chainplates in the future by ensuring that the top of the chainplate where it exits the hull and the screws are installed with a flexible sealant. If saltwater gets into the pocket that contains the gudgeon plate, it will aggressively corrode the stainless steel parts. Remember that so-called stainless steel needs exposure to air to remain corrosion-free. If immersed in an electrolyte like saltwater and depreved of air it will definitely corrode!
Jimbo
Posted : June 2, 2005 11:57 pm
