I17 Footstraps
Can someone please make some suggestions as to fitting footstraps on the I17. Are they needed and where to put them if so. The only inspection opening is behind the rear beam. The hulls are carbon fibre. Just purchased the cat and havent been out as yet. Thanks Devon
Posted : March 22, 2009 4:10 am
[Nacra 17
DESIGNER: Ross Guinea
BUILDERS: Brisbane Catamaran Centre
LENGTH: 5.3m (17’3”)
BEAM: 2.45m (8’)
DRAFT: n/a
DISPLACEMENT]
This is a Aussie N-17
Put the footstraps between the port & rear beam.
Note: Performance Sports (Nacra) never built the Aussie version of the N17, see F17 specs http://www.f17class.com/index.html They built two models, the N17 (I-17) & F17 (I-17R). Starting in 2008, Performance Sports only offer the F17 model.
Posted : March 23, 2009 12:36 pm
Forum Information
- 3,802 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
