~~18 Hobie mast lea...
~~18 Hobie mast leak~~
popeyez7
(@popeyez7)
[#652]
Hi guys... I have a problem & question 😕 You already know the problem--LEAK, I have a comp. tip Hobie 18 mast and the only place where water is coming out is where the comp joins the metal mast, and it leakin at the grove/channel where the sail slides... Is it possible to fix the leak there or would I have to try to take the comp tip out?? How far does the comp slide into the mast?? ETC ETC ETC ~~~ Any info would help alot....
Thanks~~Paul
Posted : June 10, 2009 1:06 pm
DVL
 DVL
(@dvl)
I think I have the same problem, but I am using my all aluminum mast, for now. I'll look for this thread to get answered.
Posted : June 10, 2009 1:32 pm
(@Baillie)
Newby Registered
Check gasket on the bottom of the mast for leaks.The mast rotator is prone to creating a larger hole in the mast due to movement. Also check every pop rivet to see if it is water tight. Use rtv Silicon to repair if necessary.
Baillie
Posted : June 10, 2009 3:11 pm
(@skarr1)
I didn't know Hobie's carried water in their mast. Is it for drinking or to help turn turtle?
edited by: skarr1, Jun 10, 2009 - 09:12 PM
Posted : June 10, 2009 3:55 pm
popeyez7
(@popeyez7)
I checked all rivets and everything else... I'll make some phone calls today... 🙄
Posted : June 10, 2009 8:46 pm
(@hullflyer)
The comp tip slides in approx 18"-24". The comptip should be put in with epoxy (was yours). I have put together quite a few new boats for a local Hobie dealer and they all come with a package of epoxy for this purpose.
Posted : June 11, 2009 12:34 am
(@hullflyer)
You also might want to go to the Hobie Cat Forums, as the have a thread on just 18's, lots of good information
Posted : June 11, 2009 12:39 am
popeyez7
(@popeyez7)
I bought this a couple of yrs ago, so thats the way it came.
I would have to say that it is epoxy, but I'am not going to try to take it apart... As far as I know it's only leaking from the one spot~~ right where the comp is in the sail track... Right now I have it tilted to drain the water out, then after it's all out, I'am going to use a straw on the tip of the tube of 5200 and have a go at it... it sure beats trying to rip it apart. Thats the only spot where water shows up..... everything else is good!!!
Posted : June 11, 2009 1:12 pm
