1985 Hobie 18 Hull Removal
Would someone mind giving me a brief explanation about how the hulls are removed from the frame members on a 1985 Hobie 18? Are there any issues with removing hulls?
I'm planning on injecting the deck in the upcoming months; however the boat just won't fit in my garage assembled.
The job will be a lot easier if could make the boat narrower, i.e. hull removal. Also this way I could store the boat indoors for the winter.
Any tips are much appreciated.
Once you take the boat apart it might help to look at the Assembly manual to put it back together. 😀
http://2010.archive.hobiecat.com/support/pdfs/H18&SX_Manual.pdf
rcp-1985h18sx wrote: Would someone mind giving me a brief explanation about how the hulls are removed from the frame members on a 1985 Hobie 18? Are there any issues with removing hulls?
Since you have a 1985 there is another issue you should address besides the delamination. The 1984-86 H18's were built particularly lightly and a good number of them have had a hull break off just in front of the front beam.
There are large stainless anchor plates that can be added at the beam connection and extra fiberglass cloth can be added inside the hulls at the stress points. Since you are going to disassemble and do fiberglass work anyway it would be good to do the reinforcement as well.
Don't have time to hunt down the pictures right now maybe someone else can.
Thread about the issue
http://www.thebeachcats.com/forums/viewtopic/topic/12598/start/0
Pics in tech section
http://www.thebeachcats.com/pictures/?g2_itemId=11593
- 2,384 Online
