6- or 5-inch contou...
6- or 5-inch contoured inspect port - Hobie 18 ?
(@BobBill)
[#4964]
Any reason I should not put an inspect port between the rear beam and the dagger slot?
I know hull has no bulkheads and I replaced the foam billets with pool noodles...(Special use project).
Is a 6-inch contoured port even avail?
Posted : April 7, 2015 10:01 am
(@davefarmer)
Bob,
Check with Murray's Marine, not sure about 6". And I'll check my stash, I know I bought a pair recently for the SC that were bigger than I needed.
Posted : April 7, 2015 2:58 pm
(@onekiwi)
6 inch contoured are kinda hard to find,I installed a 4 inch curved in the place you are talking about on the p19 . I bought the 6 inch flat for the B-LION and bedded them on a bed of thickened resin,looks good.
http://www.saltydogmarine.com/index.php?cPath=54&osCsid=f9b4468d37817f91eaff7d8b43800406
Edited by onekiwi on Apr 08, 2015 - 10:14 AM.
Posted : April 8, 2015 4:11 am
Scott Finley
(@smfinley)
I put inspection ports in between the rudder and rear beam. I avoided in front of the rear beam Since I would be sitting on them while sailing, and that didn't sound comfortable. I think my ports are 4" contoured. I used them to repair cracking at the rear crossbar.
Posted : April 8, 2015 12:43 pm
(@BobBill)
Sorry for late response. I check the response box, but emails I did not rec...will check spam and email in CP to be sure.
Anyway, Thanks for help. Onekiwi is right 6" curved are scarce enough I decided 5 inch will do. Hole size only 1/2 inch or so difference...
Posted : April 9, 2015 3:29 am
