Aluminum wings - We...
Aluminum wings - Weld failures
6 Users
(@timscottyoung)
[#8194]
Hello to those who have wings on their H18s.
I've had this 1989 H 18 for about 8 years. Twice, I've unpinned the wings to raise them into the stow position, and twice, the strut falls off. The entire weld around the strut just lets go.
Anyone else have this issue... is there a way to prevent? Should I just have a welder go back over all the weldments to prevent future failures? I'm a fresh water sailor, but have taken her to the beach a few times.
These wings are labeled "Formula Wings".
Posted : July 12, 2022 6:38 am
(@dogboy)
I had a welder fix and beef up the welds on my H18 wings after I them a few years ago. They seem sturdy so far. If you really want to strengthen them, weld on a gusset plate or a strut to tie the support leg into the main leg.
Otherwise, make sure that the wings are adjusted so the support struts line up properly with the outboard stainless tabs and try not to pull on the wings when moving the boat around.
Posted : July 12, 2022 12:01 pm
(@texastuma)
timscottyoung wrote: Hello to those who have wings on their H18s.
i would suggest a welder add a tab between the strut and the frame. This will help minimize movement of the strut and break the welds loose.
Posted : July 15, 2022 3:50 am
(@timscottyoung)
Do either of you know the Aluminum Alloy of the wings. Guessing the plate/tab alloy needs to match my wings.
Thanks, Tim
Posted : July 15, 2022 6:58 am
(@hullflyer)
Your boat is 33 years old, nothing holds up forever, and there is a weight limit as well.
Posted : July 15, 2022 7:45 am
(@waiex191)
Thanks, Tim
I'd guess 6061-T6. Common alloy for corrosive environments and it is weldable.
Posted : July 15, 2022 5:04 pm
(@charlescarlis)
yup, 6061, T-6 temper. About all Hobie specified. Unusually, they have made all that old tech data public. Gotta give Hobie props for that. I mean supporting boats that are a quarter of a century old or more???!!! Pretty cool.
Posted : July 15, 2022 5:15 pm
