Always more than one way...
So, over the last few years when riggging my P16, the question of whether to insert the lower portion of the main into the luff track on the mast or leave it out has nagged at me. I have done both and nothig astonishing happened 🙂 but which is right????
Every little bit helps. Keep it in the track. That will keep the downhaul in proper alignment and have the entire luff of the sail transferring power through the mast instead via the downhaul. It is not a big deal, just cleaner and doesn't stress out the sail to be out of place.
I have never seen anyone able to reef a Prindle main during a storm while sailing. If it is blowing hard enough tp consider reefing, head for shore. I would be interested if you were able to reef your sail on the water during calm weather and how long it takes. None of the newer sails have reef points.
makinmajik wrote: I think it might be hard on the sail if enough pressure was applied to the outhaul. Also might get the bolt rope stuck in the track and make it hard to strike or reef the main in a storm. My rule of thumb is, if you think you probably should do it, do it.
Mine actually has reef points although I would doubt I will ever use them. I do think dropping the sail if a storm is coming while you are on the beach would be wise and I would want to be able to do so quickly. On the water run if you can or worst case knock it over manually and right it after the storm passes is what I have been told.
Drummer63 wrote: So, over the last few years when riggging my P16, the question of whether to insert the lower portion of the main into the luff track on the mast or leave it out has nagged at me. I have done both and nothig astonishing happened 🙂 but which is right????
Were you talking about reefing?
- 5,209 Online
