Before I seal my hulls for good . . . *A Checklist*
Hey Everyone,
I have been restoring a Mystere 6.0 ( https://www.thebeachcats.com/forums/viewtopic/topic/18672)
I have have the hull lids, I have sanded down all contact areas and before I reglued these lids down I wanted to make sure I haven't missed anything.
1) Check rigging hardware isn't rusted and is securely attached to the hull
2) Ensure there are no cracks or holes on the inside of the hull
3) Reenforce where the bulkheads attached to the hull
4) Inspect centerboard housing and check for holes, cracks, etc.. Reenforce/patch where needed
5) Check for thin spots on the bottom of the hull where it may have been dragged or damaged
Have I missed anything? The last thing I want is to seal up the hulls and block myself from check or fixing something else
jgregs wrote: Hey Everyone,
5) Check for thin spots on the bottom of the hull where it may have been dragged or damagedHave I missed anything? The last thing I want is to seal up the hulls and block myself from check or fixing something else
When you refer to rigging hardware, are you referring to side stay chain plates? I am not familiar with how the Mystere chain plates are installed, but I would try to look on the inside where the chain plate enters the deck. If water had seeped from the top and sat in between the stainless chain plate and the fiberglass, it could rust and deteriorate this point. With bigger boats, this is very common failure point.
@texastuma - yes, chain plate stay thank you. I couldn't remember what they were called. I looked those over pretty well and there isn't any visible rust on anywhere. I am going to add some extra sealant for good measure but those look solid.
jgregs wrote: @texastuma - yes, chain plate stay thank you. I couldn't remember what they were called. I looked those over pretty well and there isn't any visible rust on anywhere. I am going to add some extra sealant for good measure but those look solid.
Stainless can fail without showing rust. Look at the holes the pins go through, if they're elongated replace them.
Look for cracks or any deformity. Just replace them anyway, they're cheap.
The Bore
jgregs wrote: I appreciate all the advice. I checked everything mentioned and then some and have glued the panel down as of this afternoon. Fingers crossed I hope I did everything right
Excellent.. I've gone through that on a Prindle 19 twice.. different hulls. Now to get on the water..
i agree if you inspect (use a magnifying glass) and find cracks, it is time to replace but
this is pretty serious surgury, even after the boat is opened up
the bow tangs are glassed in and would need to be hammered out to replace
the sidestay tangs have 3 bolts that are probably fused by now and also glassed in -
- 2,895 Online
