Broken rudder blades
Hey
I bought my first hobie 16 last autumn and sailed it couple of times and everything was fine. As there were some scratches on rudder blades I thought that it would be wise to repair those during the winter (fill them up with gelcoat and grind smooth again). Now when I took the boat out to the sea first time one of rudder blades broke right under rudder cams. First I thought that those things might happen and didn't mind. When I took my hobie out for second time other rudder blade broke from the same place. Might there be something wrong how I istalled rudders back to the boat or what might be the problem? Thanks in advance.
Posted : May 28, 2008 10:20 am
Forum Information
- 2,981 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
