Can you identify th...
Can you identify this catamaran sailboat?
12 Users
overruled!
327.02
#(37) “Sailboat” means any vessel whose sole source of propulsion is the wind
catman wrote: http://www.flsenate.gov/laws/statutes/2012/327.02
Read #4. They use the term Canoe and then Canoe like.
Edited by MN3 on Sep 17, 2013 - 05:15 PM.
Posted : September 17, 2013 11:02 am
here is the 2010 law for title (i can not get current year to show) - http://www.leg.state.fl.us/statutes/index.cfm?mode=View%20Statutes&SubMenu=1&App_mode=Display_Statute&Search_String=non-motor-powered+vessels&URL=0300-0399/0328/Sections/0328.03.html
here is 2011 http://www.flsenate.gov/Laws/Statutes/2011/328.03 - No change
328.03 Certificate of title required.—
(1) Each vessel that is operated, used, or stored on the waters of this state must be titled by this state pursuant to this chapter, unless it is:
(a) A vessel operated, used, or stored exclusively on private lakes and ponds;
(b) A vessel owned by the United States Government;
(c) A non-motor-powered vessel less than 16 feet in length;
(there are more)
AND
(3) A person shall not sell, assign, or transfer a vessel titled by the state without delivering to the purchaser or transferee a valid certificate of title with an assignment on it showing the transfer of title to the purchaser or transferee. A person shall not purchase or otherwise acquire a vessel required to be titled by the state without obtaining a certificate of title for the vessel in his or her name.
(there is more)
Posted : September 17, 2013 11:14 am
(@bacho)
In this case, the boat is sold for parts. None of that matters.
Posted : September 17, 2013 11:23 am
(@ready4h2o)
Little late to the party, but this may be helpful.
If it is an AHPC built Taipan, the hull ID can be found inside each hull (or pontoon?). Just open the inspection ports near the transom of each hull. Inside there will be a label with the hull ID laminated into the fiberglass.
Posted : September 18, 2013 6:49 am
(@captedteach)
Those FL DMV ppl would just hate me - I'd screw with em just because I could Break out the Constitution and show em where this is the US and you are still innocent until proven guilty They Must do the proving of guilt Not the other way around...........
Posted : September 18, 2013 12:59 pm
(@marcs2)
i have 2 18' cats in fl. with no problem with the "water nazis" incidentally oral sex is illegal in fl. and any position other than the missionary position is illegal as well.
Posted : September 18, 2013 1:30 pm
racer_x3 - i sent you a private message
Posted : September 19, 2013 4:50 am
(@rgranger)
So what about the two windsurfers I see sitting on the tramp? Do you have the rigs for those? A new rig is about $400 for those.
Posted : September 19, 2013 4:59 am
MN3, ditto, appreciate it if you can find the time to send me your opinion to the first PM I sent re the Mystere. Thnx.
Edited by Edchris177 on Sep 19, 2013 - 08:09 PM.
Posted : September 19, 2013 2:08 pm
Page 2 / 2
