Cat trax for hobie 21 se - will they work?
Hello,
Will cat trax work for a Hobie 21SE? I'm seeing two cat trax sizes listed which are 8 and 8.5 foot. I measured my Hobie today and from center line to center line it is 8.5 foot. I'm concerned the cat trax are too small for the 2SE. I hope not because I don't know if there are other options.
Has anyone used cat trax on a 21SE?
They make cat trax for pretty much every boat out there, even the 10 foot wide tornados. Just give florida sailcraft a call and ask if you are unsure. (to order you have to call anyways)
If the 21se has a 8.5ft beam, then the 8.5ft trax are the ticket, make sure you order the cradles as the ones without cradles are kind of a pain in the butt...i found out the hard way.
The 21SE has a beam of 9' 7" and my Cat Traxs are about 8' 4" center to center of cradles.
I brought my cat traxs in '89 new with my boat and they since look new. They are a very good investment. Only one flat tires over the years. 🙂
I have always wanted a second set of cat traxs as the boat is heavy and would move easier by spreading the weight on sets of cat traxs.
Edited by bill40421SE on May 27, 2013 - 03:19 PM.
I had a Super Cat 20 and got a longer axle, put a wheel on the inside and out side of the cradle to help with the weight and it worked really well. I thought about 2 sets but this solution was easier and less expensive, and allowed me to spin the boat on the beach if necessary.
bill40421SE wrote: The 21SE has a beam of 9' 7" and my Cat Traxs are about 8' 4" center to center of cradles.
I have always wanted a second set of cat traxs as the boat is heavy and would move easier by spreading the weight on sets of cat traxs.Edited by bill40421SE on May 27, 2013 - 03:19 PM.
The sleeve that they sell to widen the cat trax is expensive and a lousy fit. Go to a local metal supplier with your axle and you will find a better fitting sleeve for way less money. I bought a set off cat trax that someone shortened to use for a jet ski. I bought a piece of tubing and re-lengthened them. I used eye bolts to hold them together so that I could use the eyes to tie them on. This weekend I took them apart so they fit in the back seat of my truck. Cut cat trax are really handy.
- 383 Online
