Cheap source for shackles, hardware
Quarath wrote: I think it is a hobie rudder only thing. From the factory instead of having a perfect point on the trailing edge they flair out a bit then go to a point. It can be corrected by sanding the trailing edge somehow. I think do it because that sound means you have drag but some non racers probably just like sound because they think it means they are going fast.
I just picked up an old H17 but I have no idea if it hums or not yet.Edited by Quarath on Aug 28, 2011 - 01:27 AM.
It was the Hobie 14 and 16 primarily and yes it required sanding the trailing edge of the rudders. Mosy people keep it hummin' 🙂 I know I did, always nice to hear
Drummer63 wrote: [quote=Quarath]I think it is a hobie rudder only thing. From the factory instead of having a perfect point on the trailing edge they flair out a bit then go to a point. It can be corrected by sanding the trailing edge somehow. I think do it because that sound means you have drag but some non racers probably just like sound because they think it means they are going fast.
My N20 humms like crazy. I am in the process of fairing the rudders and daggers to see if I can get rid of it. While I do not mind the sound, I know that a hum means a vibration, which in turn means that humm is holding back a little bit of speed.
- 1,436 Online
