deck port stuck
once you get it off, take the lid and clean it in a container (so it is submerged)
use air if possible to spray out the tracks (on the boat) and finish off with a wet rag - get all the sand and grit out - will make opening easier next time
Edited by MN3 on Sep 30, 2021 - 10:53 AM.
waiex191 wrote: Here is what I did. Simple tool - piece of wood, a couple of bushings, and a couple of screws.
I needed more leverage to open a deck port last weekend and thought of this suggestion. Then I looked for something more at hand and this worked perfectly đŸ™‚
MN3 wrote: once you get it off, take the lid and clean it in a container (so it is submerged)
use air if possible to spray out the tracks (on the boat) and finish off with a wet rag - get all the sand and grit out - will make opening easier next timeEdited by MN3 on Sep 30, 2021 - 10:53 AM.
Good idea... I have been using Sailkote on the lids to help... seems to do ok.
- 328 Online
