does anyone knows how can dissmount a fx-one hull?
Try a length of wire. Perhaps even a hot wire cutter.
The Hobie assembly manual does not describe disassembly.
Have you contacted Hobie tech support?
Have you looked here?
https://www.hobie.com/forums/index.php?c=2
Edited by gahamby on Mar 03, 2019 - 12:44 PM.
I have dismounted mast steps and tramp tracks bedded down in 3M 5200 using a variable temp heat gun.
These were,however, metal to metal bonds. The aluminum tends to sink the heat away.
Try using as thin a length of 7x19 wire as you can find or some new synthetic line and a couple of trap handles.
The wooden wedge suggestion seems best. I'm not sure where you're going to run a power tool without damaging the beam (really bad) or hull (repairable).
Even without silicon, I've found that strapping the hull down to the trailer then taking a mallet to the inside of the crossbeam is needed.
https://www.harborfreight.com/professional-windshield-removal-kit-96339.html
This might do the trick if you don't want to make your own tool.
- 1,705 Online
