Double side stays on hobie 16
Definitely not something that would have come from the Hobie factory that way.
Did they add a second tang to the mast and a second anchor point to each hull, or is it just two wires per side connected to the existing mast and hull locations?
Maybe the previous owner did some distance sailing and wanted some added security against dismasting. Either way, I would go ahead and remove the second set of stays.
If you want to prevent dismasting, upgrade the standing rigging to 5/32” diameter (stock is 1/8”), replace your shroud anchor bolts and bow tangs, and check the condition of the rigging frequently (no broken strands, pins and clevis rings in good shape).
Posted : June 18, 2024 7:19 am
Forum Information
- 1,749 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
