Double trap p16
7 Users
(@jettywookie)
[#5625]
Anyone have a dual trap setup on their p16? I want to set mine up with duals for when my boys sail it. They are pretty light so I'm just wondering if it might be overkill.
Posted : August 10, 2016 6:47 am
(@Anonymous 945)
Absolutely essential for heavy air. And have them learn to tack from the wire. Pete
Posted : August 10, 2016 8:07 am
(@jettywookie)
A little advanced sailing skill for them at this point but that's the plan! Thanks Pete!
Posted : August 10, 2016 10:04 am
(@klozhald)
Double trap was an option, but a lot of P16s had them.
It is a continuous wire from the crew end, up to the hound and then back down for the skipper on each side of the cat.
Double swage the ends above the thimbles, not so important for the thimble at the top.
Salty Dog Marine and others know what to do, or you can make your own.
Buying used standing rigging is not usually recommended.
Posted : August 10, 2016 3:27 pm
(@kuba730)
Hi!
I have double trap on P16. I use not wire but 3mm dyneema and works great! A lot of fun when is blowing more than 12 knots:)
On this video you can see:
Posted : August 11, 2016 11:17 am
(@jettywookie)
Kuba! That's an awesome video! Thanks for sharing
Posted : August 11, 2016 6:49 pm
(@jalex)
Dyneema is a great choice, and very economical. Easy to splice and you can splice slip knots/loops in it to make it easily adjustable. Once you get accustomed to working with it you'll find all sorts of uses for it.
As far as double trapping a P16, not overkill at all, especially for a light crew. Also it is an inexpensive add on that is not in the way if you choose not to use it
Posted : August 12, 2016 12:37 pm
(@jettywookie)
Just researched the Deneen's and that seems the way to go for sure! I'm not much for splicing but I can tie knots!
Posted : August 12, 2016 5:57 pm
(@kuba730)
Thanks. I have one witch is better to see double trapezze but not on vimeo but on facebook. I will send it later. I use bowline knot.
Edited by kuba730 on Aug 14, 2016 - 04:11 PM.
Posted : August 13, 2016 11:02 am
(@kuba730)
Thanks. I have one witch is better to see double trapezze but not on vimeo but on facebook. I will send it later. I use rescue life knot.
Posted : August 13, 2016 11:04 am
(@kuba730)
Hi,
here is another video with double trapeze!
Enjoy:)
Edited by kuba730 on Aug 21, 2016 - 10:19 AM.
Posted : August 21, 2016 3:52 am
(@kuba730)
From Sunday (short film double trap all the time 😉
Posted : August 30, 2016 11:50 pm
knots are not a great solution for these (edit) High Modulus(end edit) "steel cable like" lines.
with enough force the knot will cut (edit) through itself(end edit).that's why riggers use eyesplices, and the bitter ends are tapered because the abrupt edge on the line can cause problems (edit) / failures(end edit).
now if your using 4mm dyneema ... the breaking strength is so ridiculously high that it's very unlikely that the weight of a few humans (even with extreme forces i.e. peter-panning, or being whipped around during a flip) i doubt it would be an issue (edit)it would be spectacular to be thrown a few dozen feet from your boat... just aim for water(end edit)
BUT chafe is a big issue here and is why many beach cats don't use high modulus lines for rigging. You have to make sure your trap lines won't rub on hounds, shackles, stays or your gonna frey your lines continuously
Edited by MN3 on Sep 01, 2016 - 12:13 PM.
Posted : August 31, 2016 7:49 am
(@jettywookie)
Kuba I'm loving your videos man! Makes me want to go sail now!
Posted : September 10, 2016 5:14 pm
(@kuba730)
jettywookie wrote: Kuba I'm loving your videos man! Makes me want to go sail now!
Special for you:)
Posted : September 12, 2016 10:36 am
tim nell
(@tnell)
[quote=jalex]Dyneema ...Easy to splice and you can splice slip knots/loops in it to make it easily adjustable. Once you get accustomed to working with it you'll find all sorts of uses for it.
I just looked at some splicing videos on YouTube...looks like some kind of voodoo magic
Posted : September 12, 2016 11:57 am
