Enlarging the deck plates
om wrote: Will that compromise the integrity of the hull?
Depends on how larger you're planning to go I suppose. Standard access ports are between 4" and 6" diameter.
6" ports can be a little large for some applications but 5" is generally OK and provides plenty of room for storing most items. I guess if you wanted to go even bigger than 6" (like a rectangular port) you could add some partial bulkheads to reinforce the deck.
Posted : April 14, 2015 9:40 am
Forum Information
- 3,487 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
