Extracting broken screws from rotomolded hull
~~ SAWSALL~~ ok, sorry bout that... just being funny!!!! How did that happen??? HMMMMMM ?? I use "Bosch" titanium drill bits. They work the best for me...... drill into it and try a 'easyout'..... that might be yer best bet. Someone else could chime in here...
Andrew ~~~ welcome to the cat club !!!!!!!! :prost:
Extract with tool as mentioned. If the holes should wallow, then use West Systems' G-Flex to repair. FOLLOW THE DIRECTIONS, INCLUDING THE HEAT/ALCOHOL TREATMENT.
G-Flex is the bomb. I've used it to repair plastic extrusion on a furler for my trimaran.
You don't have to take my word for it
http://www.westsystem.com/ss/michigan-chainsaw-kayak-massacre
motogon wrote: As I always say: if something could go wrong, it would. Extractor broken inside of that screw. I guess I have to drill out that bolt completely and try to thread for bigger size bolt. 🙁
Sounds like how my repairs usually go. 😡
Is that the port or starboard hull? If it's the starboard and you completely screw it up you could get a brand new one here.
http://www.thebeachcats.com/classifieds/catamaran-parts/p11383-new-hobie-wave-starboard-hull.html
Get some advice from a good machine shop. The problem you now have is 10 times worse than what you started with.
The easy out snapped because they are brittle, meaning hardened steel, way harder than the screw you were originally trying to back out. It is very difficult, using a hand held drill, to drill the easy out. The bit is going to want to wander off to the softer metal surrounding the easy out.
You might have to remove the entire fitting, then file the stump square & turn it with vice grips.
Those screws that may be corroded in place are generally easier to drill at nearly the full diameter of the screw shank, then run a tap through the hole, cutting new threads through any corrosion. The remains of the old screw will generally come out as you cut.
I fix it last week: used center punch to break easyout for pieces, drill out bolt completely, and tap new threads. It was bad idea to use easyout. Hobie used aluminum inserts in hulls which is bad design: aluminum + stainless steel + sea water=corrosion. There is no way to extract that old bolts, only possibility is to drill them out completely.
Thank you all for your advises!
- 4,849 Online
