F18 spin on an I20
I see a lot of F18 spins for sale and was wondering if one would work as a storm spinnaker on an I20. Would
one from an end pole snuffer work as is with my end pole or would the patches have to be reworked? This would not be for racing, just out bombing around in heavier air and training.
Thanks.
I've thought about this, but here are a few limitations:
1) Most F18 kites are setup for mid pole snuffers, 3 patch takedowns. Even a 2 patch takedown doesn't have the takedown patches close enough to the luff for an end pole, but it might work.
2) Geometry wise you may have some issues with the hoist being noticeably shorter, at least 3' or so. This will mean the F18 kite is twisted off pretty heavily, with more of a screecher shape. Not good for the kite, and tends to pull you sideways more than forward. You could play with a longer tack line but that may allow the kite to get wrapped around the end pole.
We went ahead and bought an inter 18 spin and tried it on our inter
20. After some experimentation we found using all 3 patches allowed the spin
To successfully deploy and snuff. It did bunch up more than the 20 but with a little
More effort snuffed completely. Surprisingly it raised almost to the bail. Sailing against
Other 20's, F18's and F16's, our boat seemed to sail down as deep as the others while
Providing less power and being more manageable for our light crew weight. In the future we
Will most likely rework the patches but for the first outing it was a success.
Ted I was comparing my boat to boats of very similar design, but there may have been a subliminal
forgetfulness when it came to leaving out your boat which won the class. LOL Great job and as always
a pleasure to race against you and the rest of our group.
- 1,651 Online
