Finishing and Sealing Hulls
So my first catamaran project with a 1993 Mystere 6.0 is quickly coming to a close. I'm so excited! First off thank you to everyone for all your insight and help getting me this far. I have reinforced the bulkheads, removed and resealed the hull lids, Patched multiple small cracks and holes, and reinforced some areas with extra layers of fiberglass. I believe now is the time to begin repainting and finishing the hulls. Is that correct? Is it time to start thinking paint? I still need a rigger to do new shrouds and evaluate the mast but I am trying to control and accomplish what I can before sending the boat elsewhere.
I have read mixed ideas about whether you can layer gel coat on top of other gel coat. Where I am currently is this; there are three surfaces at the moment in the hulls
1) Factory Surface (old original gell coat
2) Repaired areas m. Theses are a combination of new epoxy/ fiberglass, small hole patch like Bondo-Fiber, or squeezed out epoxy from the hull lids.
3) gelcoat covered Fiberglass where the original owner did a repair and gel coats over it. The catch here is when I unpacked Rubbermaid tubs of spare parts there was a spray can of white primer. The surface is smooth and"thick" like gel coat but I'm not sure if there is primer underneath or if he just used it where else.
My game plan was to
1) take 80grit sandpaper to the twosome or patched areas to smooth the transitions between new fiberglass and old gel coat as well as knockdown high spots from the PO's or Jon trendiest the bottom of the hulls
2) move to 120GRIT Ion an orbital sander to flatten and smooth the other repairs and scuff the factory surface
3) Wipe down the entire surface with acetone or mineral spirits and then brush on the new gel coat, Sand with 300+ to remove the brush marks and then while down and apply a wax
I'm sure I have made some nasty assumptions ( like in not sure how this will work on the kids that have some texture. Someone also suggested a thin bead of silicone where the lid meets the hull just to full small gaps and ensure there aren't any gaps - bad idea? ) but I am really excited that the structural repairs are done and this and the rigging are the final steps before getting out on the water.
Edited by jgregs on Feb 26, 2022 - 08:46 AM.
If you have some patches, it is likely you will need to fair the repairs to be smooth enough for final finish. My favorite material for this is West System Epoxy mixed with 410 Microlite filler / microballons. This material lets you form a thickened epoxy that shapes easily and has no air pockets, pits or similar problems. I use a 12-inch long sanding block to have good control over the fairing of curved and straight repairs. It's much easier using a long narrow sanding block. You can spend a lot of money, or get a cheap one from Harbor Freight that works great. This one works great for me. https://www.harborfreight.com/painting/painting-supplies/sanding-blocks-sponges/sanding-blocks/17-inch-auto-body-hand-sander-1727.html
For final finishing, I used Interlux Primekote epoxy primer and Perfection top coat. https://www.wholesalemarine.com/interlux-perfection-high-gloss-marine-paint/ It's expensive, but provides great results that are very durable. Other members have use AlexSeal 2-part paints. One advantage of paint is that repairs can be matched. For example, last summer my boat got holed during a storm. You can see the repairs in the following images resulted in a perfect invisible match. The filler shown is West 407 fumed silica over 7-layers of epoxy saturated woven glass. This was finished with 410 Microlite, faired and painted with Primekote and Perfection Arctic White.
The biggest part of the work will go into preparation. My boat was fully disassembled, and I painted the hulls while suspended from hangers. Others have used saw-horses. The boat needs to be carefully masked to protect surfaces and hardware that won't be painted, then cleaned and dewaxed BEFORE sanding. The hull parts t be painted are sanded with 180-220 grit paper and all defects fixed or removed. The hull gets wiped down again with a slow-flash solvent to ensure that the surfaces is dust and wax-free. The primer has to be totally smooth, and any orange-peel or defects will be seen in the top-coat. The primers are sandable, but to get the smoothest finish possible I thin and spray. The primer in the can can be very thick, and it can be hard to get a smooth result that does not take lot of sanding. The epoxy Primekote will work for 2-part or single part top side paint, and it is tougher and more waterproof than the original gel coat.
Single-part top paint is easier and less expensive to use, and if you have no prior painting experience may be a better choice. Lots of information on this on JamestownDistributors and videos on using the Roll and Tip method of painting. 2-part epoxy and polyurethane finishes are more difficult due to need for special thinners and the fact it just eats foam rollers. 2-part poly emits isocyanurates which are toxic, so roll and tip is the way to go if you are not a pro.
Research this on the internet and watch some videos of surface preparation and painting, and read the application guide of the paint you plan to use, then read it again. Several of us on the forum have done this and gotten very good results, and the boat can look like new, however there are no shortcuts and it takes time and the right weather conditions during painting. We can answer questions here as they come up, but you need to really equip yourself with more information and not just take my non-expert suggestions alone.
On weather conditions - typical marine paints are WAY worse about blushing for some reason. It's not about temperature so much as ensuring you're nowhere near dewpoint before cure. Like don't paint with dropping Temps in the afternoon. Prep the day before and paint in the morning. I ended up having to throw another coat on, but after sanding and re-spraying, the results were fantabulous...
So I've been reading a lot and watching videos. Here is what I'm thinking through
1) The hull lids. They have a texture build into them. Do I just need to hit this with a stiff brush while prepping the surface?
2) In the hull lids, despite being glued down, there is a slight gap in places where the adhesive didn't squeeze out and/or the fit wasn't perfect. Someone elsewhere said a marine grade silicone could be used to fill these tiny gaps. In my head it makes sense that you would address this prior to finishing but then silicone doesn't seem like the right solution. Fairing compound maybe?
3) I've read that gelcoat or paint can be used to add waterproofing. Do I need one or the other or both? I'm covering fiberglass+epoxy in some areas and Bondo Glass in others for small gap filling. I have a compressor and can buy a Wagner sprayer from Home Depot for ~$100, from the videos I've watched so far, looks like similar application
4) If I'm going to be doing large areas, it makes sense to me to do the whole thing that way I know it is done right. Agree or disagree?
jgregs wrote: 2) In the hull lids, despite being glued down, there is a slight gap in places where the adhesive didn't squeeze out and/or the fit wasn't perfect. Someone elsewhere said a marine grade silicone could be used to fill these tiny gaps. In my head it makes sense that you would address this prior to finishing but then silicone doesn't seem like the right solution. Fairing compound maybe?
To confirm, you are talking about the deck on the hulls, not the lids of the round ports on top of the hulls?
Silicone is a poor choice as is will break down and leak as the hull and deck flex differently under stress. Enlarge the space a bit with a scraper and fill with thickened epoxy.
All hull repairs I have ever done are with epoxy. The mechanical bond of polyester resin is just much weaker, but if you were using a thickened polyester to bond the deck lid to the hull, it is not something left submersed, and is an adequate adhesive that you might be able to separate in the future if you need to access inside the hulls again. Epoxy is mostly permanent. If I had some minor gaps to seal, I would use 3M 4200 not silicone. It would help to know exactly what was repaired or bonded with polyester.
tominpa wrote: All hull repairs I have ever done are with epoxy. The mechanical bond of polyester resin is just much weaker, but if you were using a thickened polyester to bond the deck lid to the hull, it is not something left submersed, and is an adequate adhesive that you might be able to separate in the future if you need to access inside the hulls again. Epoxy is mostly permanent. If I had some minor gaps to seal, I would use 3M 4200 not silicone. It would help to know exactly what was repaired or bonded with polyester.
I used polyester resin along with fiberglass cloth to fill and strengthen a crack along the front of the hull. Now I'm wondering if I need to get the angle grinder and redo it all
Well, the hull is all sealed and it looks good today. Go sailing when the weather and inclination aligns. I would let it go and see what happens rather than take any "expert" opinion here or at West Systems. Epoxy is better, but I bet you won't have a problem if the patch was well-prepared and finished. It's not like we leave these hulls in the water for months at a time.
tominpa wrote: Well, the hull is all sealed and it looks good today. Go sailing when the weather and inclination aligns. I would let it go and see what happens rather than take any "expert" opinion here or at West Systems. Epoxy is better, but I bet you won't have a problem if the patch was well-prepared and finished. It's not like we leave these hulls in the water for months at a time.
Remember the decks do more than keep water out. They provide a a good amount of structural support as well. When I removed and resealed the decks on my P-19, I used a thickened West System to rebond and never had an issue. There are a lot of different ways to rebond the decks, but keep in mind these boats are slapped together as quickly as possible and the best practices are not always used during initial production.
Good job and get out on the water, because What's the worst that can happen?
So I'm almost finished. I am currently fairing the hulls but a last minute cold snap kept the West System expoy (105+206 slow cure + fairing compound) from curing properly so it is a little gummy in spots. I'm probably going to hit it with a heat gun and try to scrape it off and redo it.
Once that is done there will be lots of sanding and then priming then more sanding and then painting. Did I miss anything?
If you're painting, be sure to use a prime coat/primer sealer for the paint to stick to. Need to go from final sand, to acetone wipe-down, evaporate and paint primer on. That has a huge impact on how well the topcoat comes out and how well it'll last. And, lastly - we need pictures!
charlescarlis wrote: . . . And, lastly - we need pictures!
After fairing several spots and sanding smooth with 240grit
A different angle. you can also see all the ropes have been replaced
Gotta do some additional sanding on the bottoms were the original owner did some lousy repairs and then sand down the fairing efforts on the opposite side. from there it is just barrier coat, prime, and paint. Last thing is to get the diamond wires replaced and back on the mast and then get the boat and trailer registered and she will be good to go!
virtual phone
he then shot a very last-spherical 76 on the carmel, ind., path on wednesday to finish in a tie for 2nd with a 4-over 220, 4returned of winner john marshall butler.i played super,” daly ii advised the indianapolis megastar. “itd had been cool to win, however i still have time. just a couple horrific 3-putts each days, however apart from that i played incredible.
virtual phone
blogsandarticlesed wrote: virtual phone
did we just get a transcription play-by-play of someone's golf game? Congrads I guess?
Man, a phone automatically pasting posts of things being done on-line is dangerous! Well, for the poster - could be entertaining for us... I sure wouldn't want a play-by-play of other "exploits"...
On another note - the boat's coming along properly! Looks like you're using a polyester-based fairing compound/glazing putty. Make sure that stuff is sealed with an epoxy sealer, if it's not completely waterproof. The manufacturer's actually post that on their data sheets. Even a good primer won't save the stuff - has to be "sealed", then primered.
Actually using West System 105 with 407 fairing compound. Made the mistake of using polyester resin on the front before I learned it wasn't water proof. All part of the learning process I guess.
JG
Hey, you got it figured out, me thinks - all good, right? Yup, all a part of the process. It's funny how you can tell that a paint project is going to turn out really good at the point the person is fairing and sanding in prep for primer - whether a car or boat. And, if I had to do it all over again, I'd probably shoot single stage automotive urethane primer and topcoat, though a bit more expensive, after the epoxy seal prime coat. It's just easier to shoot, buff, etc. However, I think the marine paints MIGHT be a little more durable...
My Two Cents...
I bought a Nacra 5.8 that had sat in the water during summers tied to a dock. Nevertheless, it was in very sad shape. I sanded at least half of the gelcoat off (my garage is still white), and primed and painted with Interlux, sanding between each coat and wiping with their proprietary thinner prep. Rolled and Tipped and voila. Took awhile to harden, and after sailing for the summer the bottom peeled and scratched in many places. I thought about it over the winter and decided to mask a strip on the bottom and paint a few coats of garage floor enamel all the way down the hull front to back. It should be pretty durable, but I am still carting my boat in and out of the water when I can. A ton of work for sure. Good luck...if you have any questions shoot me a message.
- 1,821 Online
