Glass repair
I have to do some structural glass repair on the hull edges - where the top piece meets the hull, and need to reconstruct some missing (dry and cracked - sort of crumbled) fiberglass. Since the boat was laid up with polyester resin, wouldn't it make sense to use that for the repair, rather than epoxy?
I was thinking that Bondo product with the chopped glass fibers mixed in. It needs to be tough because the part I'm repairing supports the trampoline.
Posted : July 11, 2011 12:44 pm
Post some pictures of the areas you need to repair. Most likely you will need to use a polyester resin with woven and non woven matting. The bondo with chopped glass included makes the repair itself strong but the weak point is where the repair is bonded back to the rest of the hull.
Posted : July 12, 2011 1:34 am
Forum Information
- 5,646 Online
Our newest member: nacrainter18
Latest Post: NACRA Inter 17R / F17 Rigging help
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
