H16 mama-bob
(@fshehan)
[#667]
I have an older H16 with the old style head (rounded on the top of the mast with a single large pulley for the halyard). I need guidance on how to install the bob.
Posted : June 17, 2009 5:23 am
i would contact a hobie dealer.
Posted : June 17, 2009 7:13 am
Martin
(@ufgator)
Most of the Hobie Bobs are designed to rivet to the mast and rest on the level top. Your masthead has a sing round top and is much larger. The rounded masthead is going to be the biggest problem.
I think you're going to have to make a rig that will conform to the shape of the old style masthead. You take aluminum stock and make a jig to conform to the masthead sides and extend down the side of the mast. Rivet the aluminum jig to the mast and bolt it to the bob.
Aluminum will be easy to shape but might not be strong enough to hold the bob when it strikes the water. I would use at least 1/8" thick stock. If you're creative you can cut it in the shape of a "T" with the horizontal part as the bob mount and the vertical part as the mast connection.
I hope this makes sense. Just a thought. I'm sure someone on the forum will add their two cents.
Here's a link for you.
Good luck.
Posted : June 17, 2009 7:41 am
(@PAUL624)
the question is, are you sure you want mama bob
I had one on my 18sx because I could not right it by my self without a gadget and it took a lot of time to setup while I was laying over on my side.
Be prepared as it will be harder to step the mast and right with the extra weight. It my not seem like a lot of weight but on the end of a 25+ foot lever, it can act like a ton.
have you had problems with your boat turtleing? is your mast all sealed up and water tight? It has been my experience that a 16 will float on its side for a long time before the mast fills up when properly sealed so that might be an easier fix
just my 2 cents for what it is worth
Posted : June 17, 2009 9:13 am
Martin
(@ufgator)
Good point. My old style H16 mast does fine without a bob.
Posted : June 17, 2009 3:09 pm
(@fshehan)
Great comments all. Thanks so much. I'll check on sealing my mast, while I consider a mounting method for the bob. I plan to go tip it over in the shallows to see if I can right it myself. So I can see how long the mast floats by itself without the bob.
Posted : June 17, 2009 4:50 pm
perhaps ask someone around you to assist you and go into deeper water... you don't want to risk damaging your mast/sail/cat in shallows.
Posted : June 18, 2009 3:55 am
(@fshehan)
Thanks for all the input. You guys are great. Maybe someday I can pass it forward.
Posted : June 21, 2009 6:27 pm
Martin
(@ufgator)
If you decide to fit one to your mast be sure to take some pics as you go. You can post these photos in the technical help gallery and share your ideas with others. The tech help gallery can be a great resource for help and info.
Good luck!
Posted : June 22, 2009 2:47 am
Scott Finley
(@smfinley)
You can always go flip your boat with two people on it and have the crew just float nearby and let you try righting it solo, assuming you pick a calm day. Don't let them get far from the boat, just far enough to not touch the boat or possibly get hit by it if you get the boat back up. Then again on calm days it is much harder to get the boat back up solo.
Posted : June 22, 2009 5:15 am
smfinley wrote: Then again on calm days it is much harder to get the boat back up solo.
But Always good practice
Posted : June 22, 2009 10:27 am
Scott Finley
(@smfinley)
Yes it is good to have calm days to practice both with and without your crew. It is great to have crew that is comfortable helping you get it back up, and know what to do, when conditions are not so nice.
My main point was don't have them floating near your boat while you practice in bad conditions. Go out with another boat who has extra crew in that case.
Posted : June 22, 2009 4:29 pm
