H18 Cunningham Grom...
H18 Cunningham Grommet Corroded and fell out... leaving hole in sail
(@goodsailing)
[#5061]
I riveted two flat washers over the hole and it looks like it will hold for awhile. Typically, how would a sail maker patch this? Tks
Posted : June 10, 2015 4:41 pm
(@wolfman)
This will solve the issue.
http://www.murrays.com/01-1016.html
Or take it to a sailmaker to have a new grommet put in.
Posted : June 10, 2015 6:09 pm
(@carolinacatamarans)
Take it to an awning/canvas shop or sail making and get a spur grommet installed. Should cost you $5 or less.
Posted : June 11, 2015 1:28 am
(@goodsailing)
Thanks.
Posted : June 11, 2015 3:11 am
(@wolfman)
If you put significant down haul on your sail you may find that a normal spur grommet won't hold up for long. My preference would be a riveted plate or a reinforced heavy duty steel grommet that a sailmaker can put in.
Posted : June 11, 2015 4:45 am
(@goodsailing)
I used two 2" by 1/8" thick tsteel washers, drilled holes and rivited both together over hole that was left. It was really tricky getting it together to rivet. I had to use some welding plyers / vice grips to hold it tight to compress everything so that the rivets would set properly. A temporary patch till sail is retired.
Posted : June 11, 2015 6:23 am
(@wolfman)
That'll work. You can actually buy washers like predrilled from sailrite for exactly that purpose.
Posted : June 11, 2015 6:11 pm
