H18 Halyard Hook
Yes, remove the old "flapper" hook cover.
Most of the problems with hooking the H18 main are with technique. Once you get it right you can hook and unhook reliably.
First, since you still have the flapper, do you have the Halyard Ring or are you still using the original halyard shackle?
Good, with the ring it's important to pre-twist the halyard in the opposite direction of the hook several times before attaching it to the main. That will make the ring want to turn onto the hook rather than away.
Also, make sure the knot is on the mast side of the ring to tilt the top of the ring toward the hook.
Thread Hijack Alert!! 👿
The Pentex Squaretop main from http://www.whirlwindsails.com is really powerful. With the weight of the wings plus me being one of your larger (6' 7" - 230) beachcat sailors I had really never known what it felt like to have to "depower" a rig untill I got the squaretop.
Now that I've upgraded my downhaul to the 8:1 type that the big boys use (Thanks KeySailing.com!) I have the control I need over the sail.
- 3,195 Online
