Halyard replacement
The jib halyard for my G-Cat has some burrs and needs replacement. A friend suggested as an option to wire, consider one of these new low stretch lines either 1/4 or 3/16ths. Since I don't race anymore and these high tech lines hardly stretch at all, is this a viable alternative? How about knot retention and longevity when exposed to prolonged UV exposure?
You can use Dyneema or something equivalent. For this boat, a bowline will be sufficient. I have used 7/64" tech-12 on my Prindle 19 with a large jib and never had an issue. One thing to check and consider are the blocks involved with the halyard. Take some toilet paper and rub the sheaves. You are looking for burrs or sharp points with the block. Many times a wire halyard will build grooves in the sheave and these grooves will tear up a synthetic line. Don't get too involved in the line type. If you are not racing then it really doesn't matter how high tech the line gets; it's just money...
Keep it simple, keep it affordable.
mikekrantz wrote: If you tie a bowline in any of the 12-strand dyneema lines, it will slip under pressure. However, if you put a couple of drops of splicing fluid (super glue) on the knot, it will hold...
Good idea.. I have never had a bowline in Dyneema slip out. I guess I've been lucky. To splice the small stuff, I use the needle and taper it before I splice.
OK, just to circle back to this.
I took Marlow D12 Max 99 - 2.5mm with a rated Avg Breakload @ 1,100kg / 2,425lbs
I made up 4 samples and videotaped them on the "Punisher"
Bowline only tied to the shackle failed at 408lbs -
Bowline with Superglue failed at 563lbs -
Bowline with a wrap failed at 648lbs -
Brummel eye splice with tapered bury failed at 2,091 lbs -
Edited by mikekrantz on Sep 19, 2019 - 09:50 AM.
No question using a knot is no where near as strong as a splice. To learn more about this I would suggest a google search on "seaworthy lass". I have learned more from her about what to do with my dyneema than you can imagine. Just as an aside her instructions on soft shackles is a must.
http://forums.sailinganarchy.com/index.php?/topic/185714-introducing-the-crown-jewels-soft-shackle/
mikekrantz wrote: When you're tying the bowline, instead of passing the line over the shackle pin and back to complete the knot. Make a wrap around the shackle pin and back to complete the knot.
Gotcha - that's what i thought but wasn't sure
curious how strong a regular eye splice is compared to the brummel
Strength wise, about the same. However, if you load and unload the splice over time, the straight bury can work itself out. I've seen it happen quite often on trap lines. Usually resulting in a broken tiller extension...
Thanks Mike!
I typically put a lock stitch in all my eye splices (as the samson lessons say must be used to prevent failure -
i have yet to have an eye splice fail after it being lock stitched
I also learned long ago when i fall overboard for any reason (broken trapwire, overly slippery sunscreen on legs that have gone wrong, etc) .. hold the mainsheet (for dear life) but dump the tiller extension (so far i have about a 50/50track record with remembering to dump the stick)
- 1,648 Online
