Help with Nacra 570 downhaul rigging?
I recently purchased a 2004 Nacra 570. I got the boat and a box of parts but I did not getting any rigging instruction from the previous owner. I figured everything out except for the main downhaul which is a bit more complex than on my Mystere. Not sure if I am missing a part of if I just don't understand how the two downhaul blocks are supposed to attach to the tack of the main. It came with a couple of halyard shackles with guard pins that I think are for this purpose but I can't figure out how they are supposed to attach to the tack. On the first outing I tied a piece of line in a loop through the tack and shackled to this on both sides to get me on the water. I downloaded the Nacra 570 manual but it does not show or discuss the downhaul. If anyone knows how this setup is intended to work or has pictures of one rigged up to post it would be a great help. Thanks!
See 8:1 downhaul with double blocks
The double blocks are just tied to the tack or in some cases S hooks are used.
Thanks for the ideas. I guess I am missing part of the rigging but maybe I wasn't too far off with my approach. I will also look into the S hook option. I'd still like to know how a stock 570 is rigged so if someone has a picture or can describe it I would greatly appreciate it. Thanks.
The 5.5, 5.8, 6.0, 17, f18, infusion and 20 are all the same downhaul. I don't think they dreamed a new one up just for the 570.
I have no idea what the halyard shackles with guard pins are for, never seen them used on a Nacra except for the jib halyard. Doubt they are stock.
Good luck.
- 863 Online
