Hinged tilting trailer
I have 2 options available for trailering a Wave. One is a fixed tongue trailer, the other is a hinged tongue that tilts like a snow mobile trailer. Both are dedicated cat trailers. For ramp launching, both would work. But tilt might mean the van doesn't have to go in so far. The hinge is solid. Trying to preserve the back when soloing. Any preference or experience?
It doesn't seem very useful if you launch directly to the water. If you move the boat to ground first, which is what I like to do, maybe. Or if the ramp is too flat, which is the similar to launching to ground.
I put the beachwheels near the sterns and it's quite easy to push the boat back until it tilts by its own weight, then it lands on the wheels, I push back a bit more and then I move the beachweels towards the front beam and take the boat off the trailer completely. Same thing the other way around, except that I use the winch to pull the boat up. I would see more benefit in having some rollers correctly placed for that purpose than a tilting trailer. It would depend on the trailer height either.
I agree with Andinista. I see no real value in a tilt trailer for my cat. Maybe I don't launch in the needed conditions, but with beach wheels available, the trailer tilting becomes a non issue in my mind.
Almost always can slide the cat onto wheels and wheel the cat down the ramp or beach.
I don't know what the weight difference is between a Wave and an H16 but, I can easily remove my H16 from its trailer and put it back on all by myself with the use of my beach wheels. I practice this in my back yard and give the neighbors a show. It's all about balance. I pull the boat off the trailer until it starts to tilt, then roll the wheels under and tie off to the side stays. With the boat balanced, I can wheel the thing around all over the yard. Putting it back on the trailer is just the opposite. My beach wheels are Cat Trax with the big smooth oversized rubber tires, and they work great.
Haha, yeah I have to admit that over the Easter weekend my neighbors had a lot of friends over, and I went out and wheeled the boat around on the beach wheels just for the fun of it. I got a lot of looks. I was going to raise the mast and sails but decided not too, Lol.
- 1,662 Online
