Hobie 14 rudder pins
On the H14, the rudder pins interfere with drain plug removal and replacement. It's pretty much been that way forever. I use hairpin cotter pins on the bottom of the rudder pins so that I can slide them up out of the way when I need to remove the drain plugs.
See the discussion here: http://www.hobiecat.com/forums/viewtopic.php?f=17&t=35507
Posted : March 22, 2012 6:47 am
Forum Information
- 2,044 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
