Hobie 16 Transom
I just picked up an old H16, the transom was a bit distorted, looking on line it seemed tbe cause would be wet and swollen timber in the transom. I took to it with tbe multi tool and sure enough it was wet swollen and soft. I got to the alloy plate and stopped. I’m assuming there is no timber on tbe otber side of the alloy plate ?
Posted : July 15, 2023 8:17 pm
nzhobie 123 wrote: I’m assuming there is no timber on the other side of the alloy plate ?
So:
1. See where the water is coming in and plug that, unless it's through the transom, then see #2.
2. You talk to someone who knows catamarans (especially Hobie 16s) and fiberglass, and can tell you how to rebuild it. The transom translates a lot of force to the entire boat, and deserves your respect.
Posted : July 25, 2023 2:19 pm
Forum Information
- 658 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
