Hobie 16 wrecked in Beryl is this salvageable?
Not ideal, but you should be able to use any age hull for a replacement. An older one will likely be in worse condition and significantly heavier. I believe Hobie still sells new hulls, but they're probably hard to get and will cost more than the boat will be worth when you're done. Best bet is to look for a good used matched set which will probably mean another whole boat. It all depends on how much time/expense/hassle you're willing to put up with and how nice of a boat you want to end up with.
Where are you located? We may be able to help you find some solution options.
rattlenhum wrote: Not ideal, but you should be able to use any age hull for a replacement. An older one will likely be in worse condition and significantly heavier. I believe Hobie still sells new hulls, but they're probably hard to get and will cost more than the boat will be worth when you're done. Best bet is to look for a good used matched set which will probably mean another whole boat. It all depends on how much time/expense/hassle you're willing to put up with and how nice of a boat you want to end up with.
I'm over in Houston. We've called around to a few dealers and apparently Hobie not making anymore 16s until 2025/2026. Good advice on looking around for an old one. I think I see a few on craigslist/facebook marketplace that might work in the mean time. Any advice on where else to look?
Up here in the Northeast, there are old H16s everywhere (i.e. neglected out in fields, etc and our sailing club even has what appear to be some abandoned H16s). There are times you can literally stop by the house and offer to take it away as they will give it to you for free (I was offered one for free even without inquiring about it). Never jumped at this because I like daggerboard boats and the cost of a refit sails/tramps/rigging are expensive. While I'm coming to TX soon, obviously I don't know what's the case down there. If set on repairing, I'd set up some Craigslist searches throughout the area you're willing to travel to and keep my eyes open.
James (present Corsair Dash 750 + Weta)
ex - Corsair F24-1, Pulse, 2 Farrier F25Cs, H16, 2 H17s, H18, H18SX, Bimare F18HT
nparisawan wrote: Hi all, new here, I have a H16 with a hull that got wrecked during Beryl. Is it possible for me to salvage an old H16 and do a hull replacement? I'm assuming Hobie doesn't sell any hulls right?
Edited by nparisawan on Jul 19, 2024 - 11:44 AM.
I see a ton of H16s for sale... Give me a shout and can discuss leads.. I don't own a 16 so there is no personal benefit.
- 1,736 Online
