Hobie 17 side stay/...
Hobie 17 side stay/base pulled out of hull
2 Users
(@stubbedoo)
[#149]
Hello everyone,
Just needing some help with the starboard stay/base that pulled out of the hull. Is this a fatal injury or can it be repaired? Any idea on cost either to replace or fix? The rear wing sleeve is leeking a bit on the same hull. I think I have an idea of how to fix the sleeve. Any help would be appreciated.
(spacecoast Fl.)
Posted : May 6, 2008 6:38 am
(@Anonymous 15010)
Is this what you're talking about? http://www.hobiecat.com/community/viewtopic.php?t=9293
If so, you might be able to use a drill and an easy out to remove the rest of the stud.
Good Luck
Posted : May 7, 2008 12:13 pm
(@stubbedoo)
Not quite. That threaded piece and the round bar it is screwed into pulled out of the the hull.
Posted : May 8, 2008 4:48 am
