Is this ok?
 donp
(@donp)
[#3256]
I posted this in my other thread but thought maybe I should just start another. I just want to make sure I'm not going to do any damage like this.
I was taking some of the slack out of my shroud wires and I want to know if this is enough contact for the rotation stops. Am I at my limit or can I go farther back or am I to far already?
Posted : August 24, 2012 9:39 am
Robert Braid
(@turbohobo)
What boat?
Posted : August 24, 2012 10:21 am
Robert Braid
(@turbohobo)
Is that your H14T?
Posted : August 24, 2012 10:23 am
(@bacho)
I think my h16 at full rake is pretty comparable with no ill effects.
Posted : August 24, 2012 10:39 am
 donp
(@donp)
turbohobo wrote: Is that your H14T?
yes that is my H14T. The mast rotates pretty easily but the shrouds are snug. I was worried they were to loose.
Posted : August 24, 2012 1:09 pm
(@halliske)
Tighten the forestay unless you like that much mast rake.. Perhaps use a disk homemade from a milk bottle .. Or no disk at all.. Hal
Posted : August 24, 2012 4:28 pm
(@hullflyer)
If you want to modernize, you could grind off the portion that hits the stop, add a mast rotation control. Similar to a H-18 P-18. Not really hard to do, the difference would be you would have to install the wishbone (mast rotator) and cleat on the under side of the boom instead of above.
Posted : August 26, 2012 4:04 am
(@halliske)
Reminder. Not class legal for racing !!
Posted : August 26, 2012 8:11 am
