Jib zipper lubrican...
Jib zipper lubricant
Gray
 Gray
(@gcamick)
[#1192]
What's the best lubricant for an old brittle jib zipper on a Nacra 5.2?
Posted : April 22, 2010 9:38 am
If teeth are already starting to fall off, it's probably too late for lube to help. Luckily it's not expensive to get a zipper replaced.
If it's in good condition but hard to zip, try cleaning with soap and water then lube with McLube.
Posted : April 22, 2010 10:03 am
(@pm)
gcamick wrote: What's the best lubricant for an old brittle jib zipper on a Nacra 5.2?
400 bucks!
Posted : April 22, 2010 4:35 pm
you can also use much cheaper silicone lube. it's about 1/4 the cost of mclube and works almost as well... but not as long lasting.
i spray my zippers (while raising the jib) about every month or 2, when they get tough to zip.
Posted : April 23, 2010 2:54 am
