Looking for info an...
Looking for info and/or hardware for the the rear cross beam lift for the Bimare F18HT
8 Users
J Steven
(@flightlead)
[#6999]
I am sailing an F18HT in central Florida and we can see the need to lift the rear crossbeam. I am looking for info about this and any other mods that can improve the performance of this boat
Posted : March 17, 2019 4:04 am
(@gahamby)
Can you put spacers between the crossbar and hull until you achieve the performance you're looking for and then fill the crossbar saddle with the appropriate resin and fiber. You might need longer bolts.
Posted : March 18, 2019 6:23 am
(@klozhald)
flightlead wrote: we can see the need to lift the rear crossbeam.
The crossbeam is an integral part of the cat's frame, and blends forces from the mast, hulls and trampoline. Changing it's geometry is messing with physics and structural integrity.
Are you sure you're smarter than the designer?
Posted : March 18, 2019 10:48 am
J Steven
(@flightlead)
klozhald wrote: [quote=flightlead]we can see the need to lift the rear crossbeam.
Point taken! I still need info on the lift and other performance mods that are available for this particular boat.
Posted : March 19, 2019 4:14 am
(@jack108136)
Another great boat that joined the Dead Boat Society. Somewhere here or on Catsailor is a 10 year old thread about the mod. Maybe try Lars Guck.
www.guckinc.com
Posted : March 20, 2019 1:45 am
(@rattlenhum)
While I agree with klozhald's comment in general, every 18HT I've ever seen in person had the rear beam raised to mitigate beam slap. Most were modified like JoPo's in this vid:
It's mounted on top of sections of the same beam extrusion somehow. Not sure how it's welded/bolted or how tramp attachment is handled.
Posted : March 20, 2019 2:16 am
(@dogboy)
There’s currently one of these boats for sale in the classifieds on this site. Based on the pictures, it looks like they probably shaped a riser out of foam and then glassed it into the hull. Maybe you could contact the seller directly to see if they can provide more details.
Posted : March 20, 2019 6:08 am
Normally that's the case, but evidently the designer bit the big one on the 18HT rear beam design. They all seem to be modified one way or another to raise the rear beam.
So flightlead it's not your imagination.
Posted : March 20, 2019 7:43 am
J Steven
(@flightlead)
Thanks for your input everybody
Posted : March 21, 2019 2:46 am
 duly
(@duly)
Flightless. I own a ht..if I can help..give me a call 2 five one 648 2 four 4 9
Posted : March 21, 2019 7:25 am
(@klozhald)
DamonLinkous wrote: [quote=klozhald][quote=flightlead]
flightlead- it turns out you ARE smarter than the designer!
Strong work!
Posted : March 22, 2019 8:50 am
(@rattlenhum)
flightlead:
I've uploaded this image to the Beachcats Technical Album ( https://www.thebeachcats.com/pictures?g2_itemId=131055 ):
It's a friend's Bimare F18HT, but he didn't build the beam mod....it came off another boat. As I understand it, the previous owner of the beam had it fabbed, but I don't know if it was his design or from some other source.
Hopefully this will give you some ideas for your solution.
Posted : March 24, 2019 2:32 am
J Steven
(@flightlead)
rattlenhum wrote: flightlead:
thanks Rattlehum
Posted : March 27, 2019 4:24 am
J Steven
(@flightlead)
I have since had this boat out in high winds and large chop. I was amazed how the hulls effortlessly sliced through the waves with no resistance but when the rear beam slaps, it will knock you off the boat as you go flying forward. We definitely need a suicide line for that until we get the lift kit....
Posted : December 13, 2019 3:10 am
