Mystere 5.5 Mast ball bushing
Hi all,
I bought my first beach cat the other day and one of the principal problems I'm working through is the mast step bushing. The mystere has a cast aluminium ball and a cast aluminium mast base, but the socket has a flat top, which means the normal hobie 16 cookie doesn't work.
Does anyone know what goes in here? Mine is worn badly from not using a bushing; I will need to build it up with the tig and grind it down.
https://photos.app.goo.gl/2TSQvmjLj8Jj67DSA
Posted : June 29, 2021 8:45 pm
Forum Information
- 1,592 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
