N5.2 Trampoline Slugs
I was inspecting my boat for a regatta this weekend and found two broken slugs on my rear beam. My friend has some spares, but it looks like I have to take the rear beam loose to change them out. Can I take the straps off the one offending corner, swap them out, bolt it down, and race? Seems like I have read of people bedding the beams in caulking before for stiffening.
I replaced the tramp on my Nacra 5.0 about a month ago and it should be similar. Yes, I just had to unbolt the beam on one side and the beams were not bedded down. I did the starboard side and my boat does not have the straps, just the two bolts inside the beam and a chock. Those bolts are only supposed to be torqued down to about 18 ft lbs so I brought a torque wrench with me and set it to 19 ft lbs when I took them off. This was to avoid twisting out the studs if the nut was seized on. Then set it to 18ftlbs and stopped on the first click when I retightened them. Easy Peasy but my boat is a life long freshwater boat so your mileage may vary.
- 2,106 Online
