NACRA 20 Round Boom...
NACRA 20 Round Boom OD? Length?
(@daveodonnell)
[#4280]
I purchased the boat used and the existing boom I have been told is not factory. Its currently a heavy Aluminum extrusion. I am strongly considering replacing with a round carbon tube as I see in most photos. My crew has taken one good hit from the rectangular extrusion. Round would be more forgiving, its heavy & not set-up friendly. Could use some help please.
OD?
Length? 9' (108")
Best regards
DaveODonnell@arfa-tech.com
Posted : February 2, 2014 3:31 am
(@coolhead)
New England Catamaran have one new extrusion or the complete boom for sale.
http://www.new-england-catamarans.com/hot.html
Posted : February 2, 2014 3:53 am
(@carolinacatamarans)
Do you have a picture? The original booms were a rectangle shape, in not certain round was ever offered OD. Ther rectangle booms were much tougher, my boat had a .0625 wall round tube tube was prone to damage on capsizes. I replaced it with a .120" wall tube. That all said, it's not too hard to make your own, I think you will have a difficult time trying to go with a carbon version because the boat does not sheet directly from the clue of the main like the newer boats.
Posted : February 2, 2014 10:17 pm
+1
i have a sunfish mast i hope to turn into a boom this winter to replace my heavy stock one
Posted : February 3, 2014 12:34 am
(@pm)
Nacra went to tubular aluminum booms when they upgraded hardware. Much simpler and lighter. As mentioned, very easy to make one and cheap.
Posted : February 3, 2014 9:50 am
(@daveodonnell)
With my Aluminum one the main attaches directly to main clue using a rope encircling the boom. Its really easy to rig like this, makes stress on boom almost nill.
If this were a 20 What OD and length should it be?
Edited by daveodonnell on Feb 03, 2014 - 04:55 PM.
Posted : February 3, 2014 10:46 am
You already have it rigged like that? I gave that a try but it forced the mast to rotate too much. My booms were 2" OD. Just over 9' long. On my C2 I believe the boom is 1.5' OD. It does attached to the clew like is shown but works way better than the i20 did in that configuration.
Posted : February 3, 2014 10:11 pm
