Nacra 5.2 Outhaul
Rob Hangen
(@rch701)
[#7336]
My mainsail foot is so long on my 5.2 that the outhaul doesn't provide actual tension. Should re-drill the slide 3-4" back to line it up on the back of the boom or just wait for a new main one day?
Posted : October 29, 2019 9:44 am
Rob Hangen
(@rch701)
Then again my tack is ~12" above the gooseneck. Pulling more downhaul may bring the outhaul back in range.
Posted : October 29, 2019 9:47 am
(@texastuma)
You may not have a 5.2 boom. It should be about 3-1/2" tall by 2" wide. I'm going off memory, so I may be off. But, while the sail it loose, you should be able to apply medium tension. The remaining tension should come when the downhaul is tightened.
Can you send a pic of what you are referring to as the "slide"? If I recall, there was a track at the end with a car.
Posted : November 6, 2019 3:12 am
Rob Hangen
(@rch701)
Its a 5.2 boom alright. Looks just like everyone I have ever seen pictured. I am not too worried about it now. My bolt rope might have shrunk causing the luff to be short under light tension. This makes the tack way shy of the gooseneck causing the boom to be high and seemingly too short.
Posted : November 7, 2019 2:45 am
rch701 wrote: Its a 5.2 boom alright. Looks just like everyone I have ever seen pictured. I am not too worried about it now. My bolt rope might have shrunk causing the luff to be short under light tension. This makes the tack way shy of the gooseneck causing the boom to be high and seemingly too short.
bring your sail to a sail maker - this is an easy and relatively cheap fix
if your boltrope/luff is that shrunk this is probably distorting sail shape and outhaul is a nice adjustment to have and a relatively major source of sail shape for the lower part of your sail
Posted : November 7, 2019 8:34 am
Rob Hangen
(@rch701)
Found a picture. Based on the luff crinkles I think I need to tension up the cunningham.
Posted : November 8, 2019 3:48 am
Rob Hangen
(@rch701)
You will have to right click and open the link in a new tab.
Posted : November 8, 2019 3:52 am
Posted : November 8, 2019 5:34 am
unless 5.2's have a floating gooseneck that isn't attached to the mast - your tack doesn't have any effect on your boom height (this is set by your gooseneck location)- you clew could effect the angle (height) of your boom, but your mast rake would too.
Posted : November 8, 2019 5:43 am
(@texastuma)
That's not terrible. Easy fix. Lay the sail out on the ground. At the tack, bottom of the bolt rope, there will be some heavy stitching holding the bolt rope in place. Cut this stitching loose and pull the threads out. The bolt rope will slide up the luff. Put the sail up and tighten the downhaul. This will pull the shrunken bolt rope up and eliminate most of the wrinkles. For ideal shape, take pictures from the boom up the sail. Start with no downhaul and mark on the mast each inch as you pull the downhaul. Take a picture at each mark. You can then take the pictures on the computer and compare the draft. You will find that your max draft will be about 25% downhaul tension. The benefit of this is two fold: you know where your max draft is and you can see how much the sail flattens out with max downhaul. As the wind builds, pull downhaul to flatten the mainsail. This will help keep the boat "on it's feet". On the 5.2, you know you have too much downhaul tension when you get a funky inversion bend from the tack to the batten just below the logo. We used to run a 24:1 downhaul system.
Posted : November 19, 2019 2:54 am
Rob Hangen
(@rch701)
Thanks texastuma! That is some good advice. Sounds like a good winter project for me. I was under the impression that with no rake on the diamond wires that I don't need anything like 24:1 on the downhaul. More along a 3:1 or 4:1. I had a 6:1 on my 5.0 but the total length of blocks and shackles made it ineffective.
I am talking about the end of boom elevation. I have seen many photos where the 5.2 foot is close to the boom. I have a big enough gap to jump through.
Posted : November 19, 2019 5:09 am
