Nacra 5.2 rudder bar (ackerman) angle?
I personally wouldn't bother, the gain is not significant. I see cannot tell the difference between my 5.7 (angled), & the 5.0-straight.
However, I do understand that Cat people like to tinker!
Here is a photo of my 5.7 tiller. I don't know the actual angle.
Edited by Edchris177 on May 08, 2016 - 12:26 PM.
anthony,
here is a photo of a tiller arm from my 1991 Nacra 5.8. it could be similar to what you want.
caution: i tried to do what you are hoping to do by bending a straight tiller arm using a vice. after (visibly) stressing the outer surface, it cracked the tubing. if you're going to bend the tubing, use a conduit bender like electricians use. just a suggestion.
j
Edhris177 wrote: I personally wouldn't bother, the gain is not significant.
I'm with Ed on the not worth fussing with notion. I suggest you check your rudder alignment before you do anything. If it's dead straight to very slightly toed in (up to 1/8") leave it alone. Here's what I went through.
http://www.thebeachcats.com/index.php?module=forums&func=viewtopic&topic=15766
- 2,897 Online
