Nacra 570 Jib Measurements
Hey everyone, I need to replace the jib on my Nacra 5.7. I am thinking I would like to get a 570 blade jib made instead in anticipation of eventually getting a 570 mainsail. Can anyone help me out with the measurements? Also any comments on a blade jib vs. the traditional overlapping jib?
Wolfman wrote: Yeah the 5.7 and 570 masts are both 29ft 9 inches.
This is really helpful, thanks! Would like to know the jib dimensions for the same reason.
Also, with apologies for the hijack, does anyone know what the 570 Sport spin pole dimensions are (diameter x length)?
leeboweffect wrote: [quote=wolfman]Can anyone help me out with the measurements?
So, did anyone ever come up with the leech, luff and foot dimensions for the 5.7 jib?
Sorry Nac. I posted that somewhere, maybe a few years ago...but I can’t find it now. I’ve got the measurements somewhere, maybe on an old computer that no longer lives, but I can’t find it right now. I’ll keep looking.
Edchris177 wrote: [quote=leeboweffect][quote=wolfman]Can anyone help me out with the measurements?
Here it is, thanks.
570 jib needs beam sheeting and is too tall to put on a 5.7.
5.7 masts and I have had a few 1984,1996 & 1988 are most all 29feet even (extrusion) same as 5.5sl.
570 mast is either 29 feet 7 or 29 feet 9 with the newer mast head that lowers the halyard hook. Don't know why but Nacra lists their masts plus 7 to 9. A 5.8 mast lists at 30 feet 7 and They are 30 even.
They mast hound is also 8 inches higher. A 5.8 mast slightly shortened would work.
I have a 570 main and blade jib that worked with a 18square mast and sailed ok. Was a thin 18square mast so was a bit to bendy. I will be trying a cut down 5.8 mast in a few weeks with the 570 sail set. Currently using a 5.5sl square top and standard jib. A 5.5 main looks to be the same as a 5.7.
- 1,301 Online
