Nacra Beam Straps Flush
I am racing tomorrow and I noticed many (7 of 8) of my beam straps are flush to the deck. The boat still feels rigid and the bolts are tensioned to spec. I imagine the elongated at the bolt holes being the smallest section.
Question is, should I do nothing and race 42 miles in lighter conditions solo, or do I fabricate a spacer the put between the straps and beam (think 1/16" plastic sheet or rubber or 20ga stainless steel) to give me some space between the hull and strap?
I fear messing with any of it will more than likely cause me to cancel plans.
Sometimes they touch, sometimes they don’t. If the beams seem tight, sail it.
Lift the bows & wiggle them...does the rest of the boat move? If so, they’re tight enough.
I can’t remember which model you have, but be aware there are two different straps.
There are parts lists available on the internet. That will show for sure which straps you require.
I can’t recall right now, but IIRC, the dagger boats use either the shorter straps, (or 2 long, two short).
The skeg boats use the longer straps all round.
I mis-typed, too late to edit. If they are tight enough, the boat should not wiggle.
The tramp provides much of the stiffness, but the frame alone should not exhibit slop.
Edited by Edchris177 on Jul 13, 2021 - 09:42 PM.
- 1,315 Online
