Nacra daggerboard width differences?
dave, i found this on catsailor. thanks.
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=33882
they don't say if there was ever a manufacturing difference in the boards.
ron,
would the differences between the 5.5/5.2 boards and the 5.8/6.0 boards have more to do with length and width than thickness? or if something gets shorter should it also get thinner (or thicker?) to maintain lift?
my brain is starting to hurt... 🙁
j
The 5.8/6.0 boards are much longer, a little thicker and much wider and will not fit the 5.2/5.5 trunk.
I had three pair of boards for my 5.5, trashed my original boards several times, submerged RR track, and several oyster reefs. Bought a used set that were not matched one very thin and one thick, 1 pound difference had to sand down the thick board to fit the trunk and the thin board wobbled in the trunk. Bought a third used pair that had the cutout handles and were very matched.
- 1,708 Online
