NACRA end caps won'...
NACRA end caps won't fit
2 Users
Rob Hangen
(@rch701)
[#8229]
When I tighten my beam straps in the 5.2 to 18 ft-lbs the tramp track squeezes down making the end caps not fit. It's there a torquing procedure to prevent this or do I need to make some ~9/16" plugs to insert in the track and prevent the deflection? I'd prefer to not shave the caps down as they likely worked when the boat was new.
Posted : September 4, 2022 3:10 am
The assembly manual says to install the end caps BEFORE tightening the beam straps, precisely to prevent the noted problem.
Step 7/8 in the assembly manual, where you install the straps & chips, “ Do not completel tighten the bolts at this stage.”
Step 12/13 instruct for the front trap cords - THEN install beam caps & tighten.
You can’t really shave the OEM caps to a smaller diameter, that would remove most of the rim that keeps them in place.
Edited by Edchris177 on Sep 04, 2022 - 02:40 PM.
Posted : September 4, 2022 8:35 am
