nacra masts 5.7 and...
nacra masts 5.7 and 5.8
7 Users
(@rungi)
[#7907]
Hello,
How do the mast on the nacra 5.7 and 5.8 differ?
I have a 5.8 mast on my 5.7 boat. Don't want it to fall off the ball.
I noticed a lot of shedding of the white ball and the ball seems to spin when rotating the mast.
I hope I can use the 5.7 sail on the 5.8 mast.
Anyone with experience know?
Posted : August 10, 2021 4:11 pm
How old is the ball?
Old ones, left in a high UV environment degrade. Buy a new one.
Secondly, look at the cup on the mast base.
Is there a sharp edge, or burr, that is cutting into the mast ball?
Don’t worry about the ball turning. Both my 5.0 & 5.7 do that. As the mast rotates left, it unscrews the ball 1/4 turn, when it rotates the other way, it turns the ball back down.
There may be other issues, but if your rigging is tight, the mast cannot fall off the ball
Posted : August 10, 2021 5:01 pm
(@rungi)
Ok Thanks, I am not sure the age of the ball I just got the boat.
Do you know if the 5.7 sail work on a 5.8 mast?
Does a new ball just screw on to the bolt?
Posted : August 11, 2021 2:18 am
Rob Hangen
(@rch701)
The ball just screws on by hand. I was experiencing ball spin on my Nacra 5.2. Last week I polished the mast base. I took 120grit paper and taped it over a phillips screwdriver handle and chucked it up in a drill. I followed that with 220 grit. Now it is smooth and doesn't spin the ball.
Posted : August 11, 2021 3:06 am
(@shortyfox)
Not sure if it's a good idea to let the ball rotate. A lot of focused pressure on those threads and it certainly wasn't designed for that. Mine started doing it when the ball started to flatten out at the top after a lot of use. I got a new one and hand tightened it as much as possible and then used a channel lock pliers and gave it an extra 1/8th inch, no more!
Posted : August 11, 2021 8:32 am
(@rungi)
no experts on these boats?
also anyone how the 5.8 and 5.7 mast differ?
Posted : August 11, 2021 12:14 pm
(@geepaks)
Recommend you contact BRNwatersport.com. They sell parts for all these older boats. Im sure they can give you a correct answer.
Posted : August 11, 2021 12:44 pm
(@geepaks)
found this at below link for Nacra measurement guide
5.8 mast length = 9156mm
5.7/5.5 mast length = 8858mm
Posted : August 11, 2021 12:52 pm
(@hullflyer)
I have a nacra 5.7 mast for sale, also a tramp and a rear crossbar.
Located in Delray Beach Fl 33444
Posted : August 12, 2021 1:29 am
(@revintage)
Just add a ca 30cm wire strap between head and halyard ring to compensate for the difference in length. Another more radical solution is to cut the mast top 30cm to correct length.
Posted : August 12, 2021 7:23 am
(@rungi)
So it the 5.8 mast 30 cm longer than the 5.0?
Posted : August 16, 2021 10:25 am
(@revintage)
According to the Australian paper above difference is 30cm. To make the 5.8 mast closer to the 5.7 you should cut 20cm from the base and 10cm from the top, to get the hounds at the correct height.
Posted : August 17, 2021 8:50 am
